Cap/Rotor problems...
Old Feb 28, 2009 | 05:52 PM
hvyss's Avatar
Default Cap/Rotor problems...
Been running the setup in my sig last year, and the car runs great N/A, no problems. When I spray the car, there's an intermittent miss throughout the rpm range. Plugs are gapped at .035, TR6s. Took the opti off today to find this:
Looks like the rotor button is rubbing on the cap itself.... could this be part of the problem and what would cause them to rub? This is a GM opti with an MSD Cap/rotor
Old Feb 28, 2009 | 06:51 PM
Teal94Z's Avatar
^ not sure but same thing happened to me i just changed the cap&rotor to a msd unit and it ran fine
Attached Thumbnails Cap/Rotor problems...-0527081658.jpg
Old Mar 1, 2009 | 08:28 AM
leadfoot4's Avatar
Is there any lateral "play" in the distributor's shaft, if you rotate it? It looks like the bushing that retains the shaft has worn, and is allowing the rotor to "wobble", and contact the cap as it rotates.
I recently had to replace my opti for the same reason. The car was running OK, however I was detecting a bit of a "ticking" noise, and that is what it turned out to be.
Old Mar 1, 2009 | 09:48 AM
hvyss's Avatar
Thanks guys. I am finding out this is an inherant problem with the MSD cap/rotor. Several guys over on the impala forum had the same problems. The funny thing is the car ran great all motor. Go figure
Old Mar 1, 2009 | 10:58 AM
z44ss's Avatar
wonder if msd will warranty it?
Old Mar 1, 2009 | 02:29 PM
leadfoot4's Avatar
One quick question... Were the rotor screws in tightly? If they backed out, that could also cause the rotor to wobble.
