Reg Mini starter in an LT-1???
Old Mar 1, 2009 | 07:09 PM
BobH's Avatar
Default Reg Mini starter in an LT-1???
I've got a couple mini starters lying around and my LT1's starter is giving me issues. Any chance you can use the mini from a pre lt-1 motor
thanks
bobh
Old Mar 1, 2009 | 07:12 PM
fergymoto's Avatar
As long as it is for a 153 tooth flywheel and clears the headers you can.
Old Mar 1, 2009 | 08:32 PM
Formula350's Avatar
My friend's and I use the LTx mini's on all our SBC/4.3L motors. Makes things much easier, especially if you have to remove it at some point. Helps exhaust clearance a bit too.
Along with needing the right tooth flywheel, it has to be the straight across bolt pattern, not the staggered.
I want to try the Corvette's on something next, as apparently it's a torquier starter.
BobH's Avatar
Thanks for the info, forgot about tooth count, duh, mine are 168
later
bobh
Old Mar 1, 2009 | 09:24 PM
fergymoto's Avatar
No, you're wrong, again. What else is new? It can be straight across or staggered.
