L67 injectors in LT1
Old Mar 1, 2009 | 08:44 PM
95ragtopz28's Avatar
Default L67 injectors in LT1
I remember a thread awhile discussing how many lbs an l67 injector flows at
lt1 fuel pressure. Can somebody refresh me? Please? I got 12 of them for super cheap, just hoping I can use them!
Old Mar 1, 2009 | 08:55 PM
Formula350's Avatar
This is for a 2000 L67. Since you didn't list the year yours came from, I'm just guessing. Seems to be the same since 96 though.
Checking and testing your Fuel Pressure on a L67
What is the fuel pressure of a L67 engine. GM service manual indicates 45-55 PSI at the rail test point. The average on modified engines with the stock injectors is 58PSI.
We'll go with 55PSI, and the 36.5# L67s will be 32# @ 43.5PSI.
You'll need a tune if you run them, as that's quite a jump from 24#.
Old Mar 2, 2009 | 06:00 AM
97HawkLT1's Avatar
I just got mine back from New Era Perf. where they cleaned and flow tested the ones I have from (2) 2000 GTP and they all flowed right around 38 lbs/hr at 43.5 psi. They were also all real close, less than 1.5% variation from the highest flowing to the lowest. Pretty amazing since they came from two different cars.
Old Mar 3, 2009 | 12:28 PM
Thanks for the replys guys. I do plan on another tune and getting them cleaned flow tested.
Old Mar 3, 2009 | 06:39 PM
Formula350's Avatar
Weird. What's the part numbers on them?
Old Mar 3, 2009 | 07:58 PM
97HawkLT1's Avatar
I can check the part numbers on them later but I know what the first six came out of because they came from my brothers 2000 GTP when he upgraded. The second set I got I compared to the first and they were the same numbers.
Old Mar 3, 2009 | 08:00 PM
Formula350's Avatar
I just want to see what Bosch (or who ever) tested them at for PSI Not doubting you in anyway. Though if they tested them @ 43.5, then they're like 45# in the SC 3800s!
Old Mar 4, 2009 | 07:21 AM
97HawkLT1's Avatar
The part number is 24508208. These came out of a 2000 model but I am sure they were used for several years. I am not sure where you got your numbers, but these were rated somewhere between 32-36# in the GTP. When he upgraded, he went with 42# injectors because he was at the peak of the stock ones.
Old Mar 4, 2009 | 08:10 AM
Formula350's Avatar
haha Of course, the site doesn't have info for them! -_- Lists them and the motor they came from, but that's it :\
Old Mar 4, 2009 | 11:13 AM
TAEnvy's Avatar
So would these hook right up, like the Ford racing red tops?
Old Mar 4, 2009 | 03:39 PM
Formula350's Avatar
Yea, but keep in mind you'd need a tune to compensate for the larger injectors. Otherwise they stay open too long and dump in way too much fuel, which will lead to ring wash and a ruined motor soon after.
