Do ARP rod bolts require machine work?
Old Mar 5, 2009 | 02:08 AM
ls2pontiac's Avatar
Self-Admitted Scammer
Default Do ARP rod bolts require machine work?
I just bought a new GM OEM 4-bolt main LT1 shortblock...and was going to upgrade rod bolts in it to ARP. Do the rods need machine work or can they just be put in and torqued? i have seen so many different responses that i don't know.
Old Mar 5, 2009 | 02:33 AM
GIZMO's Avatar
The right way to do this is to have the big ends honed after the rod bolts are changed. That will ensure that they are perfectly round when properly torqued.
Old Mar 5, 2009 | 12:55 PM
ls2pontiac's Avatar
How much would this cost for a machine shop to do ?
Old Mar 5, 2009 | 01:00 PM
96lt1m6's Avatar
you have to diassemble the motor and resize the rods to do this.
if you are going through all that you should put a set of H-beam rods and forged pistons in there,just my opinion though!
Old Mar 5, 2009 | 01:01 PM
ls2pontiac's Avatar
i was thinking of doing that. would i need machine work to put in a set of forged rods/pistons? its a brand new OEM shortblock, never run
Old Mar 5, 2009 | 01:07 PM
ss.slp.ls1's Avatar
You said a new shortblock...was it recently honed w/ torque plates? If not, take the block in to get it honed with torque plates to seat new rings (I figured you'd be using new rings if you are going forged pistons and H-beam rods).
Isn't it funny...new ARP rod bolts => rebuild with forged internals.
