Lifter Question
Its a really fast tick that can be heard when park in a garage or when driving next to road barriers or other cars. The higher the rpm the faster teh sound gets. Any ideas?
also make sure your header bolts are tight before you start taking apart your engine. loose header bolts or an exhaust leak can also cause a tick sound
this is what you will see when you take it off. just remove the spider tray and the dog bones and slide the lifters out
it could even be the EGR tube that connects to the back passenger side header causing the noise or leak. Do you have headers or are you stock?
, its really not that hard to distinguish between the two,,,,anyways, in ur case (97 Trans Am ws6) if the ticking is not getting louder but faster as u drive ,i believe it could be the lifter as u said cuz i had the same issue few years back, incase if its the lifter then there is high chance that it has damaged the cam as well, imo its better to also pull out the cam and check,,,,, if so, then its time to invest into a new cam/valve train setup
,,good luck
