what header gaskets?
Old Mar 6, 2009 | 12:27 AM
2XR95Z28's Avatar
Default what header gaskets?
Square or circle port? I'm gettin Percy's dead soft ones and need to know which port style, I think its square but just want to be positive...
Square-
http://store.summitracing.com/partde...5&autoview=sku
or
Circle-
Thanks guys!
Old Mar 6, 2009 | 12:56 AM
Elliott's94Z's Avatar
Wait you are running the stock manifolds right??? If so, check these ones out. http://store.summitracing.com/partde...5&autoview=sku
Old Mar 6, 2009 | 01:16 AM
robsquikz28's Avatar
u need D port style gaskets get these they are the only ones i ever use when doing installs for peeps Mr Gasket 5903 the best gasket
Old Mar 6, 2009 | 04:46 AM
RamAir95TA's Avatar
Felpro 1406s are my choice.
Old Mar 6, 2009 | 07:53 AM
Trick450r's Avatar
i got percy's dead soft's for my install this winter. Drove it yesterday for the first time (sounds MEAN) but i blew one within 50 miles...
Old Mar 6, 2009 | 10:28 AM
2XR95Z28's Avatar
I'll be running pace setter LT's what do you guys suggest?
Old Mar 6, 2009 | 11:00 AM
96formulabird's Avatar
I just installed pacesetter long tubes and i just used whatever gaskets came with the headers. they seem to be working fine. they are like felt/paper mix gaskets. idk they seem good.
Old Mar 6, 2009 | 12:46 PM
2XR95Z28's Avatar
Anyone else just use the PS gaskets? i just realllllly dont want to have them blow out on me lol. I'm sick of gaskets taking ***** on me lol...
Old Mar 6, 2009 | 12:57 PM
CptMidway's Avatar
I use Fel-Pros.
Old Mar 6, 2009 | 01:08 PM
XtraCajunSS's Avatar
I've only ever used Felpro 1406's on my LT1 builds. No problems in over 100 installs.
Shane
Old Mar 6, 2009 | 01:19 PM
crossroads's Avatar
damn that sucks im about to install some Lt's with those
Old Mar 6, 2009 | 01:37 PM
1badzee's Avatar
Get some mr. gasket coppers. they rock
Old Mar 6, 2009 | 01:50 PM
JB_97ws6TA's Avatar
I have used fel-pros not bad but for the PS you have to cut out the inboard bolt holes because they are provisioned for factory manifolds, the gaskets that come with are junk so I would advise against those, the Mr. Gasket Copper ones suck and I had a hard time with them sealing so again I do not like those but the Mr. Gasket Ultra Seal steel cores are great, I got mine at Kragen for 22 bucks and they are by far the best ones that I have used IMO
Old Mar 7, 2009 | 09:28 PM
integraxtc's Avatar
some people have said, new GM factory gaskets are best?
Anyone that can attest to that?
Old Mar 7, 2009 | 09:39 PM
spudnick3119's Avatar
Another vote for Fel-pro 1406's. I didn't have any issue with them and matched up perfectly. Another plus is that you can also install the header with the outer two bolts and drop the gasket in as the outside holes in the gasket are hangars.
Old Mar 7, 2009 | 09:55 PM
C5042081's Avatar
I had probs with the percy's alum ones , switched to Mrg 5903 problem solved
if you decide to go with the percy's you need the d-port ones
Old Mar 7, 2009 | 11:09 PM
za355tx's Avatar
After the first time using the Mr. gasket copper ones...will never use a different one. It works, won't blow out, reusable, very solid piece.
Old Mar 8, 2009 | 05:53 AM
1badzee's Avatar
