valvetrain noise under load
). I get this valvetrain noise when the car is under high load low acceleration configurations. For example, when i go up a big hill it will make the noise. It also makes the noise under hard acceleration. I have adjusted the valves twice to double check my work, and it still makes the noise. Pre-load is at 3/4 turn past zero lash (used to be 1/2 turn but figured I would tighten it a 1/4 turn more just in case that was too loose but it still makes the noise). Rather than just start taking stuff apart, I would like a second opinion. Thanks Folks. Sounds like detonation to me, and its bad. Need to find out why.
At first start up put your hand around all these areas to see if you can feel anything as well. Exhaust leaks can sounds exactly like excessive valvetrain noise. Check for loose spark plugs as well.
I installed Roller Rockers and noticed a bit of a difference but I installed valve springs and it got even louder..
I also hear my headers A LOT.. not leaking, just "exhuast".... If that makes sense..?
