PCV Kit?
Well during spring break I'm replacing my clutch but after that I'm gonna put new intake manifold gasket on since I have the infamous leak out the back. I also noticed that some of my rubber tubing for the pvc system and other things that are routed around the manifold are getting brittle and some are cracking so I am wanting to replace all of this. Is there anywhere that sells kits for this kind of thing? If not does anyone have a list of parts and/or part numbers? I will probably also just go ahead and replace the pcv valve also. FYI I no longer have egr or air systems on my car.
http://www.z28.com/forum/showthread.php?t=22729
DL the parts manual. It will give you every part number you will ever need for the 4th gen. f-body. You can also try shoebox's website: www.shbox.com
