4l60e question 95 camaro
Old Mar 9, 2009 | 01:53 PM
Georgekobe8's Avatar
Default 4l60e question 95 camaro
Well I bought my car in november and blew the tranny right away. I had the tranny rebuilt and had a tranny cooler installed, then basicly parked it till now. I took her out the other day and basicly blew a tranny line or had a fault tranny cooler. Anyways I have updated to the biggest cooler i can fit and stainless braided line right from the tranny.
Now my problem, i removed the hardlines and fittings that are directly connected to the tranny without figuring out which one was the feed and which one is the return. I can only assume which ones are which and i rather not. Can anybody help me out? there is a upper hole and a lower hole int the tranny, i need to know which one is the return and the feed.
Old Mar 9, 2009 | 04:05 PM
ss.slp.ls1's Avatar
Top port is return line.
bottom port is pressure line.
You want to have your tranny cooler in series with your return line if utilizing the radiator.
Old Mar 9, 2009 | 04:23 PM
thanks for the info
