Alarm Problems
Old Mar 9, 2009 | 04:48 PM
watkinss's Avatar
Default Alarm Problems
Thought i would send out a post before i bring my car out of storage to see if anyone has run into the same problem as i am having.
When ever its humid out or raining hard my car goes crazy. First the alarm goes off. So I disarm it and lock the car again with the remote but the interior lights stay on.. no matter how many times i press lock or unlock then lock, they wont go out and if i leave it with the lights on the alarm goes off again within 5 mins. Only way around this is disconnecting the battery.
Any help would be great
Cheers
Mike
Old Mar 9, 2009 | 07:04 PM
ss.slp.ls1's Avatar
Cheers
Mike
How do you know for sure that it only happens when its raining? If so, I'd guess that its a ground/short issue. The moisture might be allowing electricity to ground somewhere. I'd check all of the wires associated with the alarm and lights.
Old Mar 10, 2009 | 03:38 PM
watkinss's Avatar
i know it only happens when it rains cuz thats the only time it will wake me up in the middle of the night
cheers i'll give that a try
Old Mar 17, 2009 | 12:49 AM
CULATR's Avatar
Well man this is wierd cause mine is doing the same thing i just came in from checking my car out it was going out and its been raining and real humid outside and its been going nuts i disarm it and then like 20-30 seconds later it went nuts again and again??? its been working fine otherwise never had a problewm with it going off before??
Old Mar 17, 2009 | 08:39 PM
CULATR's Avatar
fixed mine it was the shock sensor ....moisture build-up in it.....alarm works like it use to now...
Old Mar 20, 2009 | 07:41 PM
watkinss's Avatar
cheers. i'll give that a look at when i take it out.
