injector question
Old Mar 10, 2009 | 06:24 AM
explicit.muscle's Avatar
Default injector question
will these injectors fit w/o any mods???
http://www.racetronix.com/01D114x.html
Old Mar 10, 2009 | 06:57 AM
DAVE00's Avatar
Yes, but you will have to tune your PCM for them before you run your car as you will be dumping gas in to the cylinders if you don't.
Old Mar 10, 2009 | 10:47 AM
ss.slp.ls1's Avatar
Originally Posted by dave00
yes, but you will have to tune your pcm for them before you run your car as you will be dumping gas in to the cylinders if you don't.
^^^+1.
Old Mar 10, 2009 | 11:05 AM
Elliott's94Z's Avatar
Exactly. During my LE2 build I put these same ones in and fired the car up a couple times to check for any timing that needed adjusted and during so, it was dumping so much fuel in that it pooped out the plugs. You should just send in your PCM before the swap and change them out while it is gone.
