svo injectors vs other brands?
Old Mar 13, 2009 | 03:13 PM
StealthFormula's Avatar
Originally Posted by Puck
Some ford vehicles do use 39psi fuel pressure, but that does not mean the injectors used were rated at the non-standard 39psi. When flowbenched they flow closer to their rating at standard 43.5psi then they do at fords 39.
Nice catch my mistake, theres a thread here where someone called Ford and they stated that the SVO's are rated at 40psi. I saw some SVO 30's flowbenched and they were something like 31.xx at 43.5psi which would mean they are rated less than 43.5psi but how much less I couldn't tell ya.
Old Mar 13, 2009 | 04:21 PM
fasttransamlt1's Avatar
So if i have a built 383 and spraying what size do you think i need to run??? Right now i have svo 30's do you think that is big enough or not??
Old Mar 13, 2009 | 04:37 PM
ss.slp.ls1's Avatar
Horsepower determines fuel supply needs aka injector size. Also wet shot/dry shot?
Old Mar 13, 2009 | 04:52 PM
It is a wet shot "175".... The went 60 ft 1.41 but it feels like it falls off on the big end....
Old Mar 13, 2009 | 05:00 PM
ss.slp.ls1's Avatar
How much hp NA are you making?
Old Mar 13, 2009 | 05:07 PM
When i had it tuned at hpe in houston it made 411 hp at the wheels...
Old Mar 13, 2009 | 05:35 PM
ss.slp.ls1's Avatar
I'd get 39-42# injectors.
Old Mar 13, 2009 | 07:10 PM
lt1andy's Avatar
The Ford svo injectors are liked because if they fail they stay open. Some of the other injectors will close if they go into a fail state.
Old Mar 13, 2009 | 07:20 PM
ss.slp.ls1's Avatar
Nice, I didn't know that.
Old Mar 14, 2009 | 01:38 AM
Formula350's Avatar
Alright, since we already had a huge debate on this and threads were thrown around with info on the subject, I can tell you that Puck is right. 99% of the Ford injectors are # rated @ 43.5psi. In one of the threads I came across an enormous injector database with flow ratings, # and cc/hr, vehicles they came from, and a boat load of other info! So, just get the part number off the side of the injector (by the plug in) and CTRL+F on this site and type in that number. Hit ENTER and it'll find it.
http://users.erols.com/srweiss/tableifc.htm
Seemingly a lot of the time, from what I saw from bench tests of users injectors, is they generally flow #1 more than their rating. Older ones of course can flow higher and lower, just due to usage over time.
I was also always told that the other nice thing about the Ford injectors were they helped atomize fuel better.
Old Mar 14, 2009 | 04:17 AM
hvyss's Avatar
I run SVO 30 lb injectors with my setup (see Sig) and am at 80% cycle duty on them. Lots of room left.
