oil pan and oil pump
Old Mar 13, 2009 | 12:02 PM
baylove's Avatar
Default oil pan and oil pump
what after market oil pans are you guys running i dont like the stock look anymore since im pulling the oil pan i might as well put in a high volume oil pump so what oil pump do you guys recommend also??
Old Mar 13, 2009 | 12:52 PM
shbox's Avatar
Try searching about HV pumps, then decide if you really want one. An SV pump with a higher pressure spring is suitable for most all applications.
Old Mar 13, 2009 | 01:01 PM
ss.slp.ls1's Avatar
So you are buying a new oil pan...for the looks?
+1. GM pump with white spring works great.
Old Mar 13, 2009 | 01:16 PM
RamAir95TA's Avatar
I am using the Canton 242T, GM white spring, Melling Select HV 10552. Not a good setup for a stockish application though.
I'd recommend either the MV55 (if on a mild setup) or Melling Select SV 10554 (once again, one for sale, PM if interested).
Old Mar 13, 2009 | 01:18 PM
baylove's Avatar
yup i need a new one because my stock pan is messed up
