Delete rear 02s?
The rear O2s detect if the cat is working right and basically are there to compare against the front O2s. If the readings are too similar it throws a SES code for you to replace cat/s. So really all you're trying to do is get a different signal than the font O2s. Where if you have no cats, you'll have the same readings, so what these people did was put in a spark plug Anti-Fouler in the O2 bung and then put the O2 into that. It apparently got the sensor out of the exhaust stream enough to change it's reading, and prevent the SES light
It's only like a $5 part and they're in the "HELP!" (by Motormite or something) area at the parts store. Or just go in and ask for one. There's a Tapered and Flat end, I'd go with the flat one. Only part number that jumps out at me is something like 42002 :\HAH! Here ya go! Even on an F-Body site
http://www.fbodyonline.com/forum/f18...337/#post24848
