more fuel problems
Old Mar 24, 2009 | 04:49 PM
6spdscreaminchickin's Avatar
Default more fuel problems
does anyone know how or if you can test the fuel pressure regulator?
Old Mar 24, 2009 | 06:02 PM
RamAir95TA's Avatar
Easiest thing to do is to pull the vacuum line off of the regulator and see if there is fuel or a strong fuel smell in it. That would indicate a hole/tear in the rubber diaphram. Or, you could hook a vacuum pump to the vacuum side and monitor the fuel pressure and apply vacuum and see if the psi changes with the key on.
