987 valvesprings?
Thanks guys
To get a 987 set up wher they have 145 lbs of seat pressure (1.730" or so), they can only handle about .540 lift before having coil bind problems.
There are some $80-100 dbl springs that can be used with your retainers, locks and locators to get you the correct pressure and still handle the lift you are after.
What is the set up ht on your springs right now?
Lloyd
Lloyd
thanks for the response lloyd. I dont know what the installed height on the current springs are. Previous owner never told me. I guess that is something i will have to measure soon?
I dont mind buying new springs, i would just rather not have to swap out almost all of my valvetrain to go with a slightly bigger cam. What double springs out there would work with the same components?
http://competitionproducts.com/prodi...p?number=98441
If you had the $$$, just buy some patriot Gold Extremes but they are $270 shipped for springs, retainers, locks and locators.
These springs I mentioned above will work with what you have though.
If they end up being set up shorter (1.750" or so), a different part # will be better unless you re shim them to get 1.800-1.820.
Lloyd
Lloyd
Would it be better to call you to discuss a custom grind or do you have any rough recommendations for me right now?
