Got WS6 Style Ram Air Hood.
Plan to run screens? If so then get the screens first before you cut so you can mark where you need to leave material as a backing to attach the screws to....then use a drill or a dremel with a cutting/drill bit and proceede to cut out as close as possible to the edge, then using a sanding bit to finish/smooth the rest...../done
Few Pics She is Dirty lined up alright but can do little tweekin
Was $435 Total.
