tranny??
Old Mar 31, 2009 | 06:38 PM
reaper97's Avatar
Default tranny??
Im trying to pull my tranny (T-56) out of my lt1 and everything is unbolted..we were able to slide it out but than it wont fully come out..is there a certain way to take out?? thanks
Old Mar 31, 2009 | 06:43 PM
ss.slp.ls1's Avatar
Originally Posted by reaper97
Im trying to pull my tranny out of my lt1 and everything is unbolted..we were able to slide it out but than it wont fully come out..is there a certain way to take out?? thanks
No where in your long sig does it say what type of transmission you have. So either you have a T56 or a stock stalled 4L60E. I am assuming that you have a 4L60E because you have 3.73 gears, otherwise you'd have gotten 4.10's.
So assuming you have an auto, is it possible that you unbolted the tranny from the engine but didn't unbolt the TC from the flexplate? You have to unbolt the TC and drop it with the tranny, otherwise the tranny will hit the body before you can pull it out far enough to drop it.
Old Mar 31, 2009 | 06:47 PM
reaper97's Avatar
sorry about that its a t-56
Old Mar 31, 2009 | 06:51 PM
StealthFormula's Avatar
I pulled my 4L60E out the other day actually. You didn't specify what tranny but if auto this applies. Make sure to disconnect the stall from the flexplate. Their are 3 bolts that hold them together. Since you have the stock stall I believe you will need a Torx 45+ tool, don't quote me on that though. Other than that did you disconnect the 2 cooler lines up top? The dipstick tube? I'm assuming you have the driveshaft and crossmember out and the torque arm disconnected so that covers everything.
Didn't catch in time that you have a T-56.
Old Mar 31, 2009 | 07:00 PM
ss.slp.ls1's Avatar
So you are trying to pull the tranny from the bellhousing first and not the trying to pull both the tranny and bellhousing at the same time correct?
I am assuming that you didn't unbolt the slave and pull the clutch fork, thereby disengaging the clutch fork from the T/O bearing. You just have to pull it outward, it will pop out about an inch, then you should be able to drop the tranny.
Old Mar 31, 2009 | 07:12 PM
reaper97's Avatar
yes correct trying to pull it off from the bellhousing....i unbolted the slave already..and i pulled the clutch fork but it wont disengaged fully ...but ill give it another go
