Suspension parts purchase...
Old Apr 3, 2009 | 04:58 PM
ss.slp.ls1's Avatar
Default Suspension parts purchase...
What do you think? Any suggestions, alternatives?
One main question I have is if going with a poly mount over a rod end on the adj. TA is a mistake?
I plan on installing all of the following. After that, I'll save for some new QA1 shocks and Strano springs. Then I'll be getting slicks and skinnies.
Suspension Mod List
--405B Tubular Adjustable Torque Arm - Long Tube Headers/Y-Pipe $369.00
Driveshaft Loop(s): Front Loop
Front Mount Type: Polyurethane Bushing
Material Type: Mild Steel
--206B Lower Control Arms - Tubular Adjustable with Spherical/Poly Combo $179.00
--210-S Rear LCA Relocation Brackets - Stock, Strange, Currie Rear Ends $59.00
--504B Tubular Sub-Frame Connectors - Mild Steel $149.00
--924-RearB Spohn Sway Bar - Solid 4140 Chrome Moly - 22mm Rear Bar $164.50
--106B Panhard Bar - Tubular Adjustable with Spherical/Poly Combo $129.00
Old Apr 3, 2009 | 05:03 PM
CamaroRacing12's Avatar
do it up!!!
i'd save and get chromoly tho but im all about weight reduction lol
