chevy small block that will accept LS1 heads
Old Apr 8, 2009 | 02:57 AM
Abdullah's Avatar
Default chevy small block that will accept LS1 heads
i think it is for the SBC not sure if there is such a block for the LT1 engines.
check out this link :
http://list.powertvmedia.com/lt/t_go...-sbc-1235.html
Old Apr 8, 2009 | 03:45 AM
Joshiedoom's Avatar
I cant wait to show this to my father......
Old Apr 8, 2009 | 06:24 AM
acammer's Avatar
Interesting, seems like you could just buy some wild SBC heads and get similar results, but very interesting. I bet lots of $$$$ for that type of a setup.
Old Apr 8, 2009 | 10:19 AM
slingshot928's Avatar
Yeah that block was in the new product showcase on here about 3 months ago or so. You need the block which is around 2000 plus a kit with a valley tray to run a distributor, and the ls heads which is around 500...and ls pistons. You can use a sbc timing set, oil pump, distributor, connecting rods and crank. Don't think it will work for the lt1, I always wanted to know if it would take the accessories from it and the front timing cover...anyone that knows or would like to try it out please post
Old Apr 8, 2009 | 10:39 AM
License2Ill's Avatar
Originally Posted by ulakovic22
Search, this has been beat to death in 2 other forums on LS1Tech alone.
So? maybe he missed them....I know I did.
Old Apr 8, 2009 | 12:23 PM
94Z28rag's Avatar
Unless you've been living under a rock you know that the LS1tech search function is the worst search engine known to man.
Old Apr 8, 2009 | 12:40 PM
ss.slp.ls1's Avatar
LOL, they even went through the effort of adding a message telling you how to use the search function effectively...instead of just changing the search back to the old functionality...when it actually worked, lol.
Old Apr 8, 2009 | 12:41 PM
ss.slp.ls1's Avatar
Seems like you would be better off just buying/fabricating some custom motor mounts and mounting a complete LS engine inside of whatever car you have instead of buying that block...
EDIT: Well I didnt think about the cylinders as aluminum LS blocks are limited to bore size...but that's what iron LSx blocks are for.
Old Apr 8, 2009 | 01:03 PM
Lets find him on other threads....using the "search" functions under his name of "Find more posts by".
Nah im kidding...you guys we beat the search guy up plenty let's let him heal now.
Old Apr 8, 2009 | 01:05 PM
FASTFATBOY's Avatar
There is no market for this, IMO they wasted their time. If you wann build a 15* headed 400+ inch Gen 1, buy a stock GM 4 bolt block and aftermarket heads. Or a Dart little M block for much less money.
You wanna build a 400+ inch LSx, 6.0 liter block and heads everywhere.
Someone had cranial rectinitus when this was thought up and developed.
Old Apr 8, 2009 | 01:12 PM
slick1851's Avatar
They should have put more effort into LT1 stuff over this, its *** back wards
Old Apr 9, 2009 | 09:40 AM
ulakovic22's Avatar
Using the shitty search function that obviously doesn't work.
https://ls1tech.com/forums/conversio...lsx-heads.html
https://ls1tech.com/forums/small-blo...-can-done.html
Old Apr 9, 2009 | 09:54 AM
Abdullah's Avatar
You're right, but considering this is an LSx site and this is a Gen1 block for LSx heads I would think someone would search before blindly posting it in the LTx forum. What does this have to do with LTx anyway?
just thought i would share what i found with you.
Old Apr 9, 2009 | 09:56 AM
ulakovic22's Avatar
I know, sorry for coming off as such as asshat, maybe I should have just said REPOST and been done with it. Probably would have gotten the same responses though.
Old Apr 9, 2009 | 09:58 AM
acammer's Avatar
Looks like original poster wasn't blindly posting, he directly remarks that this is for a SBC, and isn't sure if there is such a block for LT1. Seems like a reasonable comment, given the similarities of the SBC and LT1, and also the potential for a better breathing top end on an LT1 block - which would certainly have application in this forum. So, I'm not sure whats wrong with the original post, but thats just my $.02.
Now, like everybody else said - this is defintely a waste of time for the builder - there are better/cheaper options out there already then building a goofy hybred block like that. Interesting, yea. Practical, not really.
Old Apr 9, 2009 | 10:37 AM
kinglt-1's Avatar
Seems worth it too me. Especially when they are getting 30hp+ with the gen 1 block over the ls block due to windage. It is a little pricey for the gains tho.
Old Apr 9, 2009 | 10:42 AM
acammer's Avatar
I guess it depends on perspective - if its for a high dollar strict drag car where every last hp matters - and it really delivers better than the alternatives, then I'm sure its the way to go. For the vast majority of us street/strip guys - its not cost-effective, and straight up LSx swap would be the way to go.
Old Apr 9, 2009 | 10:44 AM
kinglt-1's Avatar
I agree, just sayin there is a market for the guys who got to have every last drop of hp out of a combination.
Old Apr 9, 2009 | 10:55 AM
How does the saying go?
Different strokers for different fockerz.....
If in the minimum cool reading. And another add to the if I won the lottery to do list.
Old Apr 9, 2009 | 01:29 PM
the_merv's Avatar
Veteran: Air Force
Interesting..
