Custom LT1 cam and LSA help
The cam specs are
With 1.6 ratio rockers
Intake lift is .564 and Exhaust is .560
Duration @ 50 is Intake 238 and Exhaust is .244
LSA 110 with 4 degrees advance (so the LSA would be 106)? Or since it is advance +4 is it 114?
Help
The cam specs are
Help
. Don't be afraid of nitrous as well - you don't need a specific nitrous cam unless you are spraying over ~250hp. A 150 shot will be fine on a 110LSA, and as you can tell already will have no problems working with EFI. Trending Topics
It's not uncommon to see +2 or +4 on N/A grinds.
110 is nothing to be affraid of .. sub-110 cams are quite common anymore.
also like puck said, too many people worry about having a "nitrous cam" when they only plan on running a 100 or 150 shot.
plus wider LSAs sound cooler
