compression
Old Apr 9, 2009 | 07:09 PM
darrell hoagland's Avatar
Default compression
what is the most compression i can run on pump gas 93 octain i in a 96 trans am
Old Apr 9, 2009 | 07:15 PM
ss.slp.ls1's Avatar
That is a very vague question that needs a lot of information to be able to answer correctly.
You have to realize the difference between static compression ratio (SCR) and the more important dynamic compression ratio (DCR) that takes into account valve events, not just combustion chamber size, gasket thickness and deck height, etc.
As far as SCR goes, I've seen up to 12.0:1 on 93 pump gas, but I don't recall the DCR.
Old Apr 9, 2009 | 08:12 PM
with my set up im gonna run 12.5 to 1
Old Apr 9, 2009 | 09:17 PM
myltwon's Avatar
mine is around 12:1 SCR haven't run it yet though, I've seen people run 12.5-8:1 SCR on 93 with LT1s
Old Apr 9, 2009 | 09:19 PM
bombebomb's Avatar
I am at 12:1 car runs ok, but it needs a dyno tune.
Old Apr 9, 2009 | 10:02 PM
palt1z28's Avatar
i run 11.5:1 compression. you should be ok.
Old Apr 10, 2009 | 12:46 PM
ok thanks
Old Apr 10, 2009 | 01:22 PM
PNYKLR-TA's Avatar
 Michael S. Palmer
