A few motor pics
Old Apr 12, 2009 | 12:31 PM
nichols92's Avatar
Very nice looking package you have there
Old Apr 12, 2009 | 12:45 PM
Ralls's Avatar
It talks about adjusting the TPS and resetting the IAC. For the TPS they want you to elongate the mounting holes and rotate it until you have 0.54 volts (TPS voltage) at idle. Then they have a procedure for resetting the IAC.
I was thinking this is their way to making it a simple bolt on and not having to get the car re-tuned. I was just going to leave the sensors alone and see if everything works out.
Old Apr 12, 2009 | 01:56 PM
za355tx's Avatar
Originally Posted by LS1 SPEED
good looking motor and sounds like a nice package
good luck getting it wrapped up and running
Thanks Larry. I'm hoping it puts out some good numbers. I don't know when I'll get it to a track though. I'm figuring the 10 bolt won't handle what it should put down. I did literately every little thing that could get me some extra HP. Even went with the smaller damper to hopefully free up a little more. I don't really know what to expect it to make but I'm hoping more than 425 rwhp.
I'm going to have Bryan Herter do the tune. He seems to think the monoblade won't be an issue.
I'll snap a pic later, it's just about ready to go in the car.
Old Apr 12, 2009 | 02:10 PM
sweetbmxrider's Avatar
Originally Posted by multmigs
That looks really good, ur attention to detail is very high and the various colors look good. That said I can't help but stare at the Alt accesory bracket which looks like you just cleaned it up and is bare alum. I'm not trying to be a jerk but it would be so much better especially later on when it starts to get dirty and oxidized if you took the time now to take it off and at least just paint it black.
i was thinking this exactly. paint the accessory bracket! also, get some nice valve covers! everything else is so purdy, those are just eye sores!!
very nice buildup though. best of luck with it and start shopping for a rear
Old Apr 12, 2009 | 07:53 PM
za355tx's Avatar
Ha I know this rear won't hold too long. I'm hoping to just get maybe one or two good solid passes to get a good time...then if it goes oh well. Here are the latest pics. It's almost ready to go in it just needs the front suspension stuff. Bet you like those LPP's and the UMI K member huh? I know I do. I'm going to custom do my own true dual setup using part of the LPP Y pipe. Once I get that done I'll definitely post pics of it.
Old Apr 12, 2009 | 10:37 PM
could you pm me your address? ima come steal yo sheit!
Old Apr 12, 2009 | 11:11 PM
za355tx's Avatar
Haha nice.
