oil level sensor plug?
Old Apr 16, 2009 | 05:52 PM
clwz28's Avatar
Default oil level sensor plug?
Has any plugged the hole in the pan for the oil level sensor?,mine is leaking between the plastic and steel on the sensor,and I dont need it any way,I am thinking its probably metric.
Old Apr 16, 2009 | 05:56 PM
ss.slp.ls1's Avatar
Why don't you need it? And it should have a seal of some kind that you can simply replace.
Old Apr 16, 2009 | 06:09 PM
BALLSS's Avatar
there is a seal...or rtv in a pinch
seal is only a few $ at GM parts counter
Old Apr 16, 2009 | 08:00 PM
the_merv's Avatar
I took a junk Sensor and made that into a Plug.
I'm sure that there is some kind of Drain Plug out there that will fit into that hole. I found one to thread into the CAGS hole on the T56.
Old Apr 16, 2009 | 08:25 PM
clwz28's Avatar
Default sensor
Its not the seal,its leaks between the plactic and the steel at the end of the sensor
