guage problems
the gauges are always off. the way the tank is designed and the floater makes it hard to get an accurate reading. if you're sitting in the car looking down or up a hill, it will go up or down because of the shape of the tank and the lack of any baffles or anythin to keep it from sloshing all over the place as ridiculously as it does. just carry a gas can with you until you can figure out how many miles you get before you need a fill up, then fill up. reset your odometer every time you fill up, when you get close to 220 or w/e you get off a tank, go fill up. thats what i do, at least.
if the fuel level sending unit were broken, it would give no resistance, making the gauge go all the way to the right as far as it could go. if it moves up and down as you drive around, well, thats normal unfortunately. also there is no low gas light for these things. if there is, it doesnt work. just keep a full tank.
If it says 3/4, it's still full.
If it says 1/2, it's 3/4 full.
If it says 1/4, it's just about empty.
I just refill when it gets to the 1/4 mark. Simple.
