Surging Idle
Old Apr 22, 2009 | 06:09 PM
93' LT1's Avatar
Default Surging Idle
Just fixed cracked heads on a 93 lt1 that i bought. I was wondering if anyone had a vacuum hose routing on not only the emissions side but I noticed that there were two hoses running to the lower front of the motor not sure what they are supposed to go to. The car has a surging idle when the car gets warmed up at a stoplight, I think it is either a vacuum leak or vacuum hose going to the wrong port. Any sugestions?
Old Apr 22, 2009 | 06:15 PM
ss.slp.ls1's Avatar
Evap diagram:
http://shbox.com/1/1995_evap.jpg
AIR & EGR ('93):
http://shbox.com/1/1993_air_egr.jpg
Old Apr 22, 2009 | 06:21 PM
93' LT1's Avatar
thanks that helps a lot. You wouldnt happen to know where the vacuum hoses that come from the front of the engine would go or what they are for?
Old Apr 22, 2009 | 06:22 PM
ss.slp.ls1's Avatar
Does it look like the bottom three squares in this diagram?
http://shbox.com/1/air_pump_recall.jpg
Also, check your intake elbow for cracks.
Same with the rubber PCV hoses:
http://shbox.com/1/pcv_pipe.jpg
Old Apr 22, 2009 | 06:27 PM
93' LT1's Avatar
Not really the only one that looked similar was the bottom right
Old Apr 22, 2009 | 06:29 PM
93' LT1's Avatar
When i put it back together i bought a new pcv hose which was just a small piece of hose shaped like U
Old Apr 22, 2009 | 06:49 PM
93' LT1's Avatar
There is one small hose with a couple of check valves in it that goes to the bottom of the engine, then there is another small one that runs behind the water pump and looks like it connects onto the timing cover
Old Apr 22, 2009 | 07:00 PM
ss.slp.ls1's Avatar
These? These are optispark venting hoses, but your '93 wasn't equiped with them. But if the previous owner bought a MSD cap and rotor, then you'll likely have them.
http://shbox.com/ci/opti_vent.jpg
http://shbox.com/1/opti_vacuum_harness.jpg
http://shbox.com/1/opti_vacuum_hose.jpg
Old Apr 22, 2009 | 07:53 PM
93' LT1's Avatar
Yeah that is exactly it, like i said just bought the car in december and have no idea what has been done or changed on it. the only difference is that i dont have a place to connect that hose to me air intake hose.
Old Apr 23, 2009 | 03:38 PM
ss.slp.ls1's Avatar
You mean the little blue plastic elbow that plugs into a little hose in the big black intake elbow? All you have to do is drill a little hole in the elbow.
