Comp 26918-16 or pac 1218-16
Also which one would you guys pick?
Going on 1.6RR's and stock cam for now.
Will be on a bumpstick around .570 eventually.
Thanks
I think there is a list of batch #'s for the springs that had issues from comp, id look for that. The batch # will be on the box when you get it.
And yes, they will work for an LT1.
Some go with the 15's vs the 18's in this situation...
and on a AL head you do want to use a spring locator
many run the 1.8" springs on non machined heads...not my choice but many do
BTW who ever said these are only good to .570 lift is wrong. Their VTG is off or something else is wrong. They are well manufactured springs
98 camaro, SMALL cam, they floated so much within 4000 miles they let the valves/pistons barely touch. I switched to patriot golds!
2006 TBSS, small cam, spring broke, lucky caught it before it dropped the valve, these springs came new with my custom cam I ordered so I ran them.
1996 Formula - cc306 cam, spring broke, dropped valve, only 15 miles on the springs. These springs were brand new and on the heads when I got them from my very good friend. Since we didn't have the box anymore or batch #, comp said they couldn't do anything about it.
I'll never run them again on any of my cars that is for sure.
