Codes for my LT4
Old Apr 23, 2009 | 07:18 AM
Greenfire's Avatar
Default Codes for my LT4
Okay I went and pulled the codes off my car. I already put a new crank sensor on the car as it was pulling that code and still is. I cleared the codes but these are back.
Codes are:
P0118 - Engine Coolant Temp Ckt high input - Could someone elaborate on this?
P0335 - Crankshaft Position sensor A circut malfunction. -has a new crank sensor installed.
P0336 - Crankshaft position sensor A ckt rng perform.
P0443 - EVAP cntrl system purge valve C fault - I think that's part of emissions that was pulled off the car.
Old Apr 23, 2009 | 01:44 PM
Greenfire's Avatar
To the top...
Old Apr 23, 2009 | 03:54 PM
ss.slp.ls1's Avatar
I would test the wires that run to the temp sensor and the cps. I would also try to find out if they are on the same circuit or not.
