Going on a diet
washer fluid
rear seats and belts
i lost the cat back and have mine dumped at the axle
heat shields
under carpet matting
theres all kinds of stuff actually
Well I just want to keep the comfort of driving it around on the street like AC and have a stereo to listen to. My motor is borderline to radical for the street.
The car is a pig I weighed it at a lil over 3500 without my 205 pnd fatass in it. I would like to lose about 200 pnds out of it without the AC or stereo.
-door bars
-cut fender lining
-cut frame back to radiator support
-front and or rear bumper support
-ditch ur catback (if u have one)
-run light weight carpet or remove ur sound deadening
-e brake assembly (unless u use it)
-front sway and all brackets (im sure its out already)
- rear seats/rear seat belts
-cut all misc crap u dont need out
-abs delete
money mods:
-lighter wheels
-chromoly cage (if u have a mid steel cage)
-alum or cf driveshaft
-drag brakes
-manual brake set up
ect ect there is alot more u can do but im getting tired
-door bars
-cut fender lining
-abs delete
money mods:
-lighter wheels
-drag brakes
Thats what I wanted.
I dont have a cage yet
probably gonna get kicked off trackI do have skinnies up front prostar rims
I think I am gonna start with bumper supports and ABS i heard that itself weighs about 50 pnds
Yea you are right I am a lil hesitant but this car may see about 200 miles a month if that total street/strip
From diching my ORY and Magnaflow Catback for my dumped X-Pipe I shed almost 60lbs. The rear seat and cushions weight in or around 30lbs. and the rear seatbelts and assembly weigh 7lbs. The spare and jack weighs 37lbs. and the rear cover weighs 3lbs. The AIR/EGR are good for 12-15lbs. and swapping from the stock DS to an LS1 aluminum shed me 5.5lbs of rotational mass.
That's just some very basic things you could yank out or swap to in a couple hours.
