what plugs should i go with?
Old Apr 27, 2009 | 12:49 PM
93TAJ.C.'s Avatar
Default what plugs should i go with?
I have a bolt on 1993 trans am with lt's cai, tune, new opti, wires, and may too many parts to list. I went with ngk tr6 plugs that came with my msd wires for 110. Iv been told they are too cold and are used for nitrous guys. Should i go with a tr55 instead? What should i gap them at?
Old Apr 27, 2009 | 01:22 PM
ss.slp.ls1's Avatar
^Yes.
Old Apr 27, 2009 | 01:57 PM
kinglt-1's Avatar
tr55 gaped at .45
Old Apr 27, 2009 | 02:10 PM
StealthFormula's Avatar
I run some Autolite 104's which are equivalent to the TR6's but that is because my combustion chamber temps are so high with my heads and everything. Before I touched my heads I had always ran the NGK TR55's with great success and would highly recommend them.
You could check your owners manual but if I recall correctly the factory recommended gap is .50.
Old Apr 27, 2009 | 02:14 PM
kinglt-1's Avatar
factory gap is .50, but I thought the tr55's should be gapped down .05 from stock since they are not platinum.
Old Apr 27, 2009 | 02:51 PM
Elliott's94Z's Avatar
Autolite 104's or NGK TR6's
Old Apr 27, 2009 | 03:10 PM
camerory's Avatar
Make sure you go with stock gap (.050) like others have said. No problems with the platinum autolites and now I have irridium autolites and they work well too. I picked up a set of irridium autoilites for $45 which is about $15 less than ngk and they are already to the correct gap.
Old Apr 27, 2009 | 03:20 PM
Z-RATED94's Avatar
I don't know about others, but my car seems to like the TR6s gapped at 35, whether it's on the bottle or not.
Old Apr 27, 2009 | 03:44 PM
riceburnerZ28's Avatar
Use the tr55s ! I'm confused about the spark plug gap...I have 2 different repair manuals and they recommend two different gaps....0.35 & 0.50. Which one for modified engines?...my guess would be lower than .50 but higher than .35 or does it matter?
Old Apr 27, 2009 | 05:55 PM
camerory's Avatar
My 1995 Factory manual says spark plug gap should be 1.27mm (0.050") for the 5.7L (VIN P) engine. I would guess running nitrous or a higher compression engine would require a smaller gap 0.035".
Old Apr 27, 2009 | 06:22 PM
kinglt-1's Avatar
correct me if I am mistaken, but isn't the .050 gap specification for platinum plugs? And If you switch to convetional copper core plugs, then don't you have to gap them down a bit?
Old Apr 27, 2009 | 06:26 PM
camerory's Avatar
Yes you are correct, platinum plugs were installed from the factory and that is what the service manual is referring to. I am not sure on your second statement though, I have seen 0.050 for all plugs. I don't know much about changing the gap for copper plugs.
Old Apr 27, 2009 | 07:02 PM
lt1-xjs's Avatar
tr55 gaped at .45
Like he said.
Old Apr 27, 2009 | 09:08 PM
With your setup I would do .35. I was recommended by a very reputable sponsor on here and a local shop to run a .35 gap with my car.
Old Apr 27, 2009 | 09:12 PM
Razor_Blade's Avatar
I run regular old copper Autolite 106's gapped at .40.
Old Apr 27, 2009 | 10:24 PM
litch2004's Avatar
i ran tr55 at .45
Old Apr 28, 2009 | 07:31 AM
LM97Z's Avatar
I agree, TR6s gapped at .035" are great for a bolt-on LT1, especially if your into the throttle alot or run more timing, mine ran great with these plugs on a N2o tune with timing pulled under WOT, so if you have bolt-ons & a perf. tune, this is the plug i would use, my 2 cents.
IF you decise to run the TR55s, gap them at .050"
Old Apr 28, 2009 | 07:44 AM
moehorsepower's Avatar
Just remember widening the gap of the plug isn't always the best route to go and may hinder performance, unless your ignition system is up to the task then a bit of a lower gap is preferable. Excessive gap with puts a strain on the ignition system...
Old Apr 28, 2009 | 09:25 AM
93TAJ.C.'s Avatar
Ok so what would happen if i gapped my tr6's at .050? Would it run like **** at low rpm's and possably even run lean? I know it probubly wouldent run lean, but maby run like ****? I ask because mine runs really bad and is supposably running lean. I think the guys that told me its running lean are wrong, so does ion at mad z28. I think the problem is plugs, wires, or opti. I just know im running the tr6 at .050 and thats not right for a mild bolt on car. But it does seem to be ok at wot.
Old Apr 28, 2009 | 12:37 PM
Sounds good ! Well I will pull the rest the of plugs..regap them and see what happens..thanks !
