valve seal??s
Old Apr 29, 2009 | 04:19 PM
reaper97's Avatar
Default valve seal??s
Im finally getting my 355 build but i just realized that when i did my cam swap i didn't replace the valve seals on the heads so im going to replace them well the heads are off but my question is which ones do you guys suggest part #s would be appreciated? thanks
Old Apr 29, 2009 | 04:35 PM
ss.slp.ls1's Avatar
Either GM replacements or Felpro replacement valve seals will work fine.
Old Apr 29, 2009 | 05:22 PM
StealthFormula's Avatar
I don't have the part# but your best bet is to go to your local gm dealer and order some new stock ones.
Old Apr 29, 2009 | 08:22 PM
RamAir95TA's Avatar
Definitely stick with OEM or Fel-pro seals. The K-line "wiper" style are garbage.
Old Apr 29, 2009 | 10:44 PM
riceburnerZ28's Avatar
I highly recommend the felpro seals. Fel-Pro QSS72861 $18.25 for set of 16
