long tube install
thanks
Remove steering joint on drivers side. Alternator, belt, starter, and dipstick tube on pass. side.
Remove egr and air line fittings and lines. I just cut mine as i didnt plan on keeping them. Block off with gaskets etc.
Loosen bolts on cats. I used a impact to do so as i was impatient and didnt spray anything down with pb plaster/liquid wrench. I lucked out, nothing broke, i dont suggest just doing the same
I cut the y pipe in the middle as again i wasnt keeping it, and ground away at the weld at the I pipe till the y pipe was loose . Removed all of that.
Remove plugs and wires then manifolds. I actually just loosened the manifolds, removed the wires, and then broke all the plugs as i yanked it out. THen removed what was left haha.
Headers go in from bottom, extremely easy. Didnt have to lift the motor or anything for me.
Then pretty much reverse. Seems like i got the basics of it
Search online for some undercarriage pics, you should see where everything will sit.
