lt1 sputter problem
Old May 6, 2009 | 03:27 PM
lt1formula275's Avatar
Exclamation lt1 sputter problem
my 1993 trans am auto Lt1 is having problems when i press the gas, it sputters and hesitates until i let off the gas. it will not increase in speed unless i barely press the gas. i replaced the fuel filter and it didnt correct the problem. car idles fine but misses when you give it gas in all gears. i had the transmission checked out and everything was fine. The car has around 63k miles on it.
help would be appreciated.
Old May 6, 2009 | 03:36 PM
itSSlowZ28's Avatar
check for burnt plug wires, loose boots or maybe check the spark plugs. also check out the fuel injector connections. that should get you started.
Old May 6, 2009 | 04:00 PM
ss.slp.ls1's Avatar
Any codes?
Test your fuel pressure.
Check/replace your plugs and wires like mentioned above.
Test/replace your coil.
Check your o2's with a scanner.
Check for vacuum leaks.
If nothing else works, you might need a new opti.
