about how much power
Old May 8, 2009 | 06:34 AM
shutzero's Avatar
Default about how much power
should i expect from a cam with these specs 223/230 .565/.565 112 LSA all the mods in my sig, new springs, 1.6rrs, and pushrods
Old May 8, 2009 | 07:59 AM
Elliott's94Z's Avatar
A4 or M6?? That's the Lloyd's Hot Cam version if I remember correctly. Same camshaft I ran only mine was on a 109lsa.
Old May 8, 2009 | 08:21 AM
shutzero's Avatar
Its an a4
Old May 8, 2009 | 12:07 PM
ss.slp.ls1's Avatar
Default Cam
Good enough to drop you into the 12's when paired with a quality 3000+ stall.
That cam is similar to the CC503 but should make more power through the whole power band. You won't be disappointed. You will want to add a stall and trans cooler though. If I had to throw out a number, I'd say 330 through an A4.
Old May 8, 2009 | 05:32 PM
shutzero's Avatar
and what about this cam 226/230 .565/.565 111 LSA this doesnt NEED a converter to run correct?
Old May 8, 2009 | 05:35 PM
ss.slp.ls1's Avatar
Both cams should be very comparable.
You don't need a converter, but the car will likely feel sluggish without one.
Old May 8, 2009 | 05:36 PM
shutzero's Avatar
i just want to be able to install everything and drive it until i can afford a converter...for a dd what stall converter should i go with?
Old May 8, 2009 | 05:49 PM
ss.slp.ls1's Avatar
I'm not an expert on auto's, both my cars are M6's. But you definitely want something in the 3000+ range. Probably a 3400-3600 stall, but ask other more informed people first.
Also, you will have to tune your car, and then update your tune once you get your stall in.
Old May 8, 2009 | 05:54 PM
1badzee's Avatar
x2.. possible cam surge or the car may actually stall out when slowing down or at lower RPMs. I made that mistake once >.<
Old May 8, 2009 | 05:57 PM
shutzero's Avatar
Even if both those cams say u don't need one?
Old May 8, 2009 | 05:58 PM
ss.slp.ls1's Avatar
There is a difference between "need" and "fully optimizing your set up to take full advantage of that cam".
Old May 8, 2009 | 06:02 PM
SoxXpupPeT's Avatar
not to but 330 through an A4 ? i should be Very happy with my set up then
and agreed. you could run your car with the stock converter. but it wont be As good as it could be.
Old May 8, 2009 | 06:09 PM
BLK,97,T/A,M-6's Avatar
Should be about as much power as a hydrogen bomb, with as much torque as a saturn 5 rocket! LOL sorry, had to do it.
Old May 8, 2009 | 06:17 PM
shutzero's Avatar
Ya I'm not going to race without the converter I just want to be able to drive it safely without the converter if its possible
