lt1 single plane info needed
Old May 10, 2009 | 10:26 AM
killaxtranz's Avatar
Default lt1 single plane info needed
ok sooo i am gonna go with a single plan on my 383 already got the heads holes in the rite place and the intake is not giving me problems but then i look to see wat to us as a throttle body no has really perfected the 90mm low end lean-out so i wanted to no your guys oppion on this or what some of you did.
https://www.hallspeedshop.com/images...rock/29783.jpg
Old May 10, 2009 | 02:38 PM
Dave J's Avatar
I run a 90mm acufab on a supervic and it runs great
I have the tune a bit fat if anything
Old May 10, 2009 | 03:22 PM
i have the same heads as you ported by ai and would like to get those numbers but with the hydrolic rollers can you suggest me a cam thats still streetable and could probly get me in the 10's. is it the ls1 kind or the mustang kind and Does everything hook rite up to teh accufab or is there some modifaction needed?
Old May 11, 2009 | 12:48 PM
Stroked96Bowtie's Avatar
I would suggest looking into the 860performance elbows that nitrous outlet sells. They will take a factory style TB which makes install much easier. Do a google search, it'll come up.
