93 Z.. Which timing set?
Old May 14, 2009 | 01:34 PM
1badzee's Avatar
Default 93 Z.. Which timing set?
In the middle of doing a TH350 swap I decided to change all the seals on the motor, and alas, I discovered my timing chain was loose as hell, so time to replace. I have a 1993 LT1 though - what options do I have for timing chains (avoiding 95+ conversions)?
Old May 14, 2009 | 01:37 PM
93cz28's Avatar
Your mom is loose as hell
Old May 14, 2009 | 01:41 PM
1badzee's Avatar
stfu queerboy
Old May 14, 2009 | 01:42 PM
litch2004's Avatar
you only have OE option. unfortunately we are screwed due to the opti spline drive shaft.
Old May 14, 2009 | 01:44 PM
za355tx's Avatar
The only options you have having the non-vented opti setup is to go with a stock replacement. Lunati sells one for around the same price as GM sells theirs. However the Lunati piece is a stock setup with their name on it. That's the one I'm using. There are literately no other options if you keep the non-vented setup. Below is the Lunati link for summit. Part number is lun-93094
http://store.summitracing.com/partde...4&autoview=sku
Old May 14, 2009 | 01:46 PM
ss.slp.ls1's Avatar
OEM replacement
You can get the parts from GMPartsDirect
10128346 crank sprocket
10128349 '93-'94 cam sprocket (10206039 '95-'97 cam sprocket)
10128485 timing chain
