Need help on possible ignition problem
Anyway, I just did the icm relo mod and now I noticed a very slight miss while stopped at a light when the engine was at normal operating temperature and had only been run for about 5 minutes. And very gently at that.
I realize it most likely could use plugs and wires. The check engine light is not on and I have not attempted to pull codes. However, I turned the lights off in the garage and started the car to look for wires shorting out and while I didn't see any sparks there (like you can see the wires!) I did notice that the coil was glowing a faint blue or pink on both sides where the metal guard (or whatever you call that box it's in) is. I turned the lights back on and looked closer and notices that it appears that the cylindrical part of the coil is actually touching it on the driver's side. After turning the lights back off and refiring the car there is a definite pink- orange- reddish glow on both sides.
Have I found the problem or a problem or is this normal? It appears to be the stocker btw.
I appreciate the help.
I would still like to know if the coil should glow like that.
Micah
i can see how spark plugs could glow through the ceramic but coils are insulated and in a metal shell, are they not? i wouldn't think light should penetrate, but an electrical short yes. i don't know. Anyone?
