modify the factory lt1 harness
Old May 15, 2009 | 09:09 PM
67LS3's Avatar
Default modify the factory lt1 harness
i am installing a 95 lt1 with a factory harness in an earlier vehicle with a turbo 350. i need to know if i can cut out the trans wires from the harness? shouldnt need a vss signal to run. i can tune for issues but i question the vss signal. also is there anywhere online that has good info on modifying the factory harness for standalone operation?
Old May 19, 2009 | 07:32 PM
67LS3's Avatar
no links to sites on modifying the harness?
Old May 19, 2009 | 08:28 PM
RamAir95TA's Avatar
Since the transmission won't be computer-controlled anyway (you're using a TH350), you can cut them. You can also have the trans tables tuned out.
