should i buy it?
Old May 17, 2009 | 10:11 PM
93TAJ.C.'s Avatar
Default should i buy it?
I found a caliper to caliper rearend for 250 with richmond 4.10 gears and stock posi. The gears only have 500 miles on them. I know this is an insane deal but i want to be able to have reasonable rpm's at 80 with my 1993 t56(geared a little different than the 1994-2002 t56) anf 17x9 ws6 wheels. I would be at about 3000 wouldent I? Thats just too high. I have 3.23's now and hate them, specially after i jusns yanked the motor, gave it all new gaskets and seals, and added lt's, cai, 24# svo's, and madz28 tune.
Old May 17, 2009 | 10:26 PM
s1ck s0n's Avatar
i dunno man, i have 4.56 gears and i dont hit 3k until 100mph.
Old May 17, 2009 | 10:51 PM
93TAJ.C.'s Avatar
do you have a t56?
Old May 17, 2009 | 10:55 PM
Purple95Z28's Avatar
I don't remember the exact RPM but with 4.10s I was doing 2300 or 2400 in 6th at 80 I think.
Old May 17, 2009 | 11:00 PM
93TAJ.C.'s Avatar
hmmmm, anyone else running 4.10's with t56? I need to make my mind up before 2 oclock tomarrow and its 10pm here right now! im a penny pincher, but with all the mods iv done (i forgot to add a ton of ****, and just did umi sfc's and hurst pro billet shifter the other day) it would really be a huge gain im sure.
Old May 17, 2009 | 11:03 PM
s1ck s0n's Avatar
yeah i have a t56, i say go for it! i was skeptical about the 4.56 gears myself. but theyre a blast on the street.
Old May 17, 2009 | 11:54 PM
Johnny-LT1-runner's Avatar
Rockstar
Everyone I know with a T56 has 4.10s. they are a perfect combo.
Old May 18, 2009 | 12:51 AM
93TAJ.C.'s Avatar
sweet, thanks guys. Im gunna see if i can pick it up asap, like tomarrow. And then ill see how long i can keep my liscence, the rice is heavy here in colorado, and by rice i mean evos and sti's. So iv got my work cut out for me.
Old May 18, 2009 | 12:57 AM
itSSlowZ28's Avatar
gears, full exhaust, cai, and a tune you should be swattin the rice pretty easily, as long as they're close to stock
Old May 18, 2009 | 10:46 AM
95zsean's Avatar
Try this calculator:http://www.f-body.org/gears/
Old May 18, 2009 | 02:32 PM
93TAJ.C.'s Avatar
according to that chart ill be at 2700 at 80 with the 4.10's. Is that right? Thats way to high for a 700 mile roadtrip at 80mph.
Old May 18, 2009 | 02:52 PM
litch2004's Avatar
3000 rms would be if you had 4.10's on an A4
Old May 18, 2009 | 03:35 PM
Schweet97Z's Avatar
@ 80 mph you will right around 21-2200 rpms.
Old May 18, 2009 | 04:31 PM
ss.slp.ls1's Avatar
Nice come up, I think the increased rpm won't be an issue. Not big enough to trump the low end gains at least.
Old May 18, 2009 | 05:53 PM
camar0corey's Avatar
2700rpm would be too high for a 700 mile trip? People used to spin 4k all day on the interstate on the way to the track, I think we are getting too spoiled with the double overdrive.
They are fun, forget having traction on any sort of street tire though.
Old May 18, 2009 | 05:55 PM
nik1703's Avatar
I just made a thread about this, you'll be at roughly 2600 rpm @ 80mph in 6th gear.
Old May 18, 2009 | 06:03 PM
ss.slp.ls1's Avatar
LOL, I agree.
2600 is nothing.
Old May 18, 2009 | 10:54 PM
93TAJ.C.'s Avatar
I know it is possable to spin that high for that long, i just dont want to. In the last 4 months i've pulled the motor and did the following:
intake gasket
pan gasket
valve cover gaskets
throttlebody gaskets
lunati timing set
timing cover gaskets
egr b/0 plates
water pump
msd cap & rotor (yes it is working fine)
msd wires w
ngk tr55 plugs
24# svo injectors (had 22# stock)
tune by ion
poly engine and tranny mounts
pacesetter race lt's with 3" ory
felpro header gaskets
k&n fipk cai
slp airfoil
tranny output shaft seal
umi subframe connectors
hurst pro billit shifter
icm
17x9ws6 wheels
275/40/zr17 sumitomo htrz tires
monroe sensa trac rear shocks
brakes in all 4 corners with d/s rotors (not cracked yet)
20% tint
keyless remote
master window switch
driver's side doorhandle
driver's side window
t top sunshades
gatorback serpinine belt
pioneer mp3 player
alternator
fuel pump
heated o2 conversion with ac delco 3 wire o2's
new fans with shroud
I know alot of this is little thing but it adds up so fast, i just thought i'd put all i could think of so that you would see how much i've invested so far. Adding it all up actually realize how much I've spent.
Old May 19, 2009 | 01:03 AM
rkinney's Avatar
You are correct. I have an M29 t56 with the .62 6th and run 3.73's. I run just under 2500 at 80. With 4.10's you will be just under 2700 with a 275/40/17 tire. A 4.10 with a M29 t56 is like a 4.56 in a 94-02 t56. That is why I went with a 3.73, it's more like a 4.10 for me.
Old May 19, 2009 | 10:47 AM
93TAJ.C.'s Avatar
yeah i just talked to a local speed shop who konws the difference between the t56's. he said the same thing you just did. So I will be looking for a 3.73 rear. I would buy gears but my 15 year old posi doesent like to grab for right hand corners. Maby ill just get a new posi, gears, and girdle for my current rear.....Freakin money pit.....
