TPS? Or OPTI? 02s? Or What?
Code 15- Coolant sensor circuit-low temperature indicated. Verify engine is not under cooling, such as a thermostat sticking open. Check wiring and connections to sensor. Replace sensor
Code 27- EGR vacuum control solenoid circuit. Check the EGR solenoid wiring and connections.
Code 29- Secondary Air Injection. Check the wiring and connections for shorts.
Code 36- Distributor ignition system. Faulty high resolution (360X) pulse or multiple low resolution pulses detected. Check pigtail connector from distributor to main harness for any opens or shorts. Verify wiring is okay before replacing distributor.
Code 42- Ignition control circuit (ignition module). Check wiring and connections from ignition module and ecm. Replace module only after verifying wiring and connections are not shorted or open.
