Fuel pressure question
Old May 18, 2009 | 10:37 PM
nastyiroc's Avatar
Default Fuel pressure question
I have a autometer pod gauge in my car that says fuel pressure. What do those usually show in what part of the lines pressure and is that the same as when you put a gauge on the check valve on the motor? And what is good pressure on the autometer or on the check valve how ever it works for a 1995 trans am?
Old May 19, 2009 | 10:04 AM
nastyiroc's Avatar
Any help on this?
Old May 19, 2009 | 12:53 PM
ss.slp.ls1's Avatar
No idea where the autometer gauge is hooked up so I can't help you there.
However, if you hook up a fuel pressure gauge to the schrader valve, you want to see anywhere from 41-47 psi at KOEO and idle (with the vacuum line disconnected from the fuel pressure regulator). You want to see it hold pressure even after you shut of the car. You will also want to prop up the gauge against the windsheild so that you can close the hood and view it while you drive. You want to watch the fuel pressure as you go WOT under load and check to see that the pressure doesn't drop off.
Old May 19, 2009 | 08:34 PM
nastyiroc's Avatar
So where could the autometer gauge possibly be reading from and what should the pressure be on there? Does it read different pressures at different parts of the fuel system?
Old May 19, 2009 | 08:38 PM
RamAir95TA's Avatar
All fuel pressure gauges (on stock lines) tap into the Schrader valve.
Why don't you just look?
Old May 19, 2009 | 08:51 PM
Schweet97Z's Avatar
The schrader valve being located @ the back of the intake manifold right by the fuel pressure regulator.
http://shbox.com/1/fp_reg.jpg
Old May 19, 2009 | 08:53 PM
Schweet97Z's Avatar
Also if for some reason the gauge is tapped in before the pressure regulator it will read higher, because the pressure isnt at a regulated state...
Old May 19, 2009 | 08:54 PM
litch2004's Avatar
depending on the year. my 93 has the schrader valve on the side of the intake manifold on the drivers side right in the middle.
Old May 19, 2009 | 09:01 PM
nastyiroc's Avatar
So wat should be a good pressure on my autometer gauge?
Old May 19, 2009 | 09:05 PM
Schweet97Z's Avatar
Like stated above....41-47 psi.
