exhaust valve question
Old May 20, 2009 | 09:16 AM
BigZee71's Avatar
Default exhaust valve question
I got my heads off. On one bank the exhaust valves are all white except for one. On the other side all the exhaust valves are dark, almost the same color as the intake vavles except for the #8 which is white like the other side.
What can cause this? o2's?
Old May 20, 2009 | 12:53 PM
ss.slp.ls1's Avatar
Check the condition of the plugs. Should tell if if you were running excessively lean or rich.
Old May 20, 2009 | 01:59 PM
BigZee71's Avatar
I think thats is something i should have mentioned. All the plugs look uniform to me. All the same lightish brown.
Old May 20, 2009 | 02:00 PM
ss.slp.ls1's Avatar
Did you check the head gaskets to make sure that you didn't have any leaks? Did the piston tops look uniform as well?
