Shimming the starter...
Will a washer in between the starter and the block (on each bolt?) be enough?
I would try to get another starter under warranty and tell them you need a shim kit, they should have them avaliable.
I bet the solenoid in the starter is going bad, which doesn't allow the gear to retract normally.
Has anything changed, did you check to make sure the starter isn't loose?
