turbo 350 swap
Old May 22, 2009 | 09:53 AM
jankie93z's Avatar
Default turbo 350 swap
what all will i need to do to swap my 93 camaro 700r4 to a turbo 350? crossmember starter shifter drive shaft length?
Old May 22, 2009 | 10:51 AM
jankie93z's Avatar
anyone? im about to buy the tranny so i wanna now what to expect
Old May 22, 2009 | 12:34 PM
engineermike's Avatar
I'm sure a search would turn up lots of info. In short...
- Converter
- Transmission
- Longer driveshaft, however, the stocker will work on a long-tail TH350
- Cross member
- Torque arm adapter
- Speedo adapter
- Modify transmission cooler lines
- Run a vacuum line to the intake
- If you want kickdown to work, you have to install the kickdown cable
- Dipstick tube
The stock shifter will work, but the 1st gear position won't exist.
Old May 22, 2009 | 04:30 PM
jankie93z's Avatar
who makes the crossmember?
Old May 22, 2009 | 06:28 PM
ss.slp.ls1's Avatar
https://ls1tech.com/forums/automatic...questions.html
