Injector impedance? driveability issues
I checked the fuel pressure at the rails and it was only about 30 psi. I bumped it back up to 45 psi w/ my adj press regulator and that seemed to take care of 'some' of it's driveavility issues (idle & low rpm's). The injectors are stock and they are 160K old. Im not quite ready to buy new ones as I prob should due to thier age and mods done to the car, but want to find my exact prob before I start throwing parts at it. What impedance should the injectors read? Im sure the opti may also be part of the prob also, but I'll get there w/ that.
I did have the coil tested out already and it's ok and new plugs are installed.
thanks!
You need to check the fuel pressure while driving and see if the pressure drops when the car "falls on it's face"...
Also, another thing is to check plug gaps and the ignition coil. As RPMs go up so does spark demand. A weak coil will show itself more at higher RPMs than idle.
