1.6rr ??
Old May 26, 2009 | 09:03 AM
fuzzyjk's Avatar
Default 1.6rr ??
It was recommended by a forum member to get 1.6rr (NSA) how do these stack up to those (1.6 rr (crane gold) 3/8 stud sa)? I was told the (NSA) would be goog for 10-12 HP).
Old May 26, 2009 | 09:24 AM
GoFastKid's Avatar
Me personally I would run the nsa 7/16 for the addicinal strength over the Crane SA 3/8. Yes, they wwould be good for another 8-12 at the rear.
Old May 26, 2009 | 01:07 PM
CRAZZ28's Avatar
Make sure you get guide plates and hardened pushrods to go along with those NSA rockers.
Old May 26, 2009 | 03:56 PM
ss.slp.ls1's Avatar
Agreed with the above...7/16" stud NSA 1.6 rr's. Either Crane Golds or Comp Pro Mags would be my recommendation. Get hardened pushrods and guideplates as mentioned. You will also need LT4 springs at the minimum.
Old May 26, 2009 | 05:29 PM
ThreeHonks's Avatar
+1 I think with pro mags you will need to clearance the valve covers though
Old May 26, 2009 | 06:03 PM
ss.slp.ls1's Avatar
Easy job, took me 10 mins with a grinder taking my time.
Old May 26, 2009 | 07:01 PM
ThreeHonks's Avatar
oh thats not bad at all. I have heard ppl make a big issue about clearancing them... I have the same rockers for my build so thats why I ask
Old May 27, 2009 | 12:21 AM
CaramelPleasure's Avatar
Default please explain
Was reading this thread and i am now wondering if someone can give me a link or explain to me how you get horsepower by simply changing to 1.6s? Not being sarcastic, i just have little knowledge on this and just dont see how.
Old May 27, 2009 | 01:32 AM
1eyedmaro's Avatar
You gain power by loosing friction and by opening the valves higher. Full roller rockers have almost no friction compared the stock cast rockers being that they pivot using bearings. They have a ratio of 1.6 instead of the stock 1.5 ratio. For example a .500 lift cam using 1.5 rockers is a .533 lift cam when using 1.6 rockers. And being that the ratio is higher, the valves are open higher throughout the whole duration of the lobe which means a lot more air flow. Full roller rockers also have a roller tip where the valve meets the rocker. This also means less friction.
Old May 27, 2009 | 01:38 AM
so realisticly, without any exaggeration, how much horsepower are you truly looking at getting with a completely stock lt1 switching from 1.5s to 1.6s?
oh and ty very much for the explanation.
Old May 27, 2009 | 01:42 AM
1eyedmaro's Avatar
around 10-12 horsepower. That is why they are so recommended.
no problem.
Old May 27, 2009 | 01:55 AM
1eyedmaro's Avatar
Read this article about roller rockers:
Roller Rocker Article
Here you can see that most of the horsepower is gained from the reduction of friction. With that being said, it is safe to say that you will not see the same gains from using them with stock springs as compared to aftermarket valve springs which have higher seat pressures.
Old May 27, 2009 | 02:04 AM
wow that's amazing. i may look into them once i do some more homework as far as what type to get. again thx man.
Old May 27, 2009 | 11:18 AM
ss.slp.ls1's Avatar
You can't use them with stock springs, you will get coil bind and bad things will happen. You need LT4 springs at the minimum. With stiffer springs, hardened pushrods are highly recommended also.
Old May 27, 2009 | 09:40 PM
deerslayinrednek's Avatar
I went with the 1.6 SA Crane Golds and the LT4 springs Im very pleased with them. Since I've added them and removed my speaker box with 2 12" Subs I've picked up 3-4mph in the quarter mile......I'm very happy with mine, but I believe if i were going todo it again I would just go with a set of NSA and guideplates
