lt1 idle problem
Old May 26, 2009 | 09:17 PM
1994formulalt1's Avatar
Default lt1 idle problem
i have 95 trans am and when i start the car after not driving it for a couple of hours it does not want to hold idle so i press the gas to about 2500 rpms for about 30 seconds then it will hold the idle if i dont press the gas the car cuts off. what do you think the problem is?
Old May 26, 2009 | 09:47 PM
Wooshie's Avatar
mine did this recently. it was just a cracked vacuum line from when i had the intake off last. fixed for less than 1$.
Old May 26, 2009 | 10:41 PM
ok i'm going to change the fuel filter 2moro and if thats not it ill check cus my friends z28 had a similar problem which we could hear the hissing from the vaccume line so we fixed that
Old May 26, 2009 | 10:47 PM
moderate Z28's Avatar
Could be a bad IAC. I had that problem. The car wouldnt idle when cold but would idle when warmed up.
Old May 27, 2009 | 08:34 AM
would the iac throw an engine code?
Old May 27, 2009 | 09:59 AM
z28lt1rocket's Avatar
definately
Old May 27, 2009 | 09:21 PM
damnit
