Weird idle issue
Old May 28, 2009 | 12:10 PM
69gto96z's Avatar
Default Weird idle issue
I rebuilt my motor 2 summers ago, motor in sig with a cc306. It has a mail order tune from MadZ28 on it. Ever since I built the motor it has ran great, idled good. But a couple of times a year it will idle weird. As soon as I push the clutch in the idle drops to about 500 rpm and the car just slowly dies. But if I keep my foot on the gas slightly it stays alive. The car still feels strong and runs good other than that. Like I said it only does this a couple of times a year, and it will do it for a day or two, then go back to normal for another 6 to 8 months. I was thinking a vacuum leak but the car idles fine for a minute or two after first starting it, and then it starts doing it. Anybody have any ideas or ever seen this before?
Old May 28, 2009 | 12:13 PM
69gto96z's Avatar
Also, the car is not throwing any codes. And it does this when it is cold and when its warm.
Old May 28, 2009 | 12:17 PM
ss.slp.ls1's Avatar
That's very strange for it to die when you only put in the clutch...
Old May 28, 2009 | 06:24 PM
69gto96z's Avatar
I know, its weird. It was doing it today, then after I posted and went back to work it stopped doing it. About 30 min ago it did it again on my way home. Crazy thing
Old May 30, 2009 | 05:15 PM
69gto96z's Avatar
I put a volt meter on my TPS, it was reading .54, and is supposed to be reading .67. I adjusted it, and the car is idling a lot better now. Still not as good as it has though, im going to tackle the IAC next.
Old May 30, 2009 | 05:27 PM
shutzero's Avatar
are you able to read the iac counts?
