Estimates on HP and track times please
Old May 29, 2009 | 02:59 AM
moderate Z28's Avatar
Default Estimates on HP and track times please
With the mods in my sig, what would be my flywheel and rear wheel HP if I added the LE1 heads and an EWP? What about the LE2 heads and EWP? Would high 11's be possible or am I looking at low 12's? I know the cams old but Im not going to change it for this car. Thanks.
Old May 29, 2009 | 08:42 AM
94Z28rag's Avatar
There's no reason you shouldn't be in the mid-high 12s now with some traction.
Old May 29, 2009 | 09:37 AM
^Thanks. Yes I realize that. I was just wondering how much either heads will add to it and which heads, LE1 or LE2, are the best with my mods.
Old May 29, 2009 | 09:52 AM
94Z28rag's Avatar
LE1s are all you need...the Hotcam is tiny and you don't have any serious supporting mods --- LT's being first and foremost.
Old May 29, 2009 | 09:57 AM
kinglt-1's Avatar
With the le1's and the hot cam, I would say low 12's. 11's would be pushin it. Is it a4 or m6? If it's a4 you would need a stall for sure, or it might not even be capable of low 12's. Most le2 setups with the le custom cam trap 118-121 and run anywhere from High 11's to low 11's.
Old May 29, 2009 | 10:37 AM
Is it really worth it to go with LT's over the mids? I am now wondering if I should go with the budget LE heads or the LE1. I should probably go ahead and do
LE1 just incase I want to get the supporting cam later.
