Ls1 driveshaft
Old Jun 9, 2009 | 12:45 PM
dafhturbo's Avatar
local DS shop quoted $75 to rebalance stocker.
Old Jun 9, 2009 | 12:59 PM
Formula383's Avatar
Here's mine twisted in half last year at the shootout. This was on Nitto DR's and only 3K RPM. I say keep the steel one or go aftermarket. I've got a Strange chromoly DS now. I believe it was around $399.
And the video...
http://www.youtube.com/watch?v=JCxJM...e=channel_page
Old Jun 9, 2009 | 01:23 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
The LS1 shaft looks surprisingly thin.
Old Jun 9, 2009 | 01:33 PM
AChotrod's Avatar
It works better than the stocker but is weaker. I would do it and keep the stocker as a back up.
Old Jun 9, 2009 | 01:54 PM
RamAir95TA's Avatar
I said to hell with both of them and bought a Chromemoly Denny's Nitrous-ready shaft. No questions asked.
Old Jun 9, 2009 | 02:00 PM
BlackScreaminMachine's Avatar
Internet Mechanic
LS1 D/S will work for most street cars. Transmission or year doesn't matter Any serious track use at all, it should be considere to be replaced. BUT one thing that people forget is suspension, tire, and RPM of the launch.
If the car is an auto with a street tire, I would not at all worry.
My car got a 3" Denny's Steel D/S and works great. The Car picks up wheels.
https://ls1tech.com/forums/eastern-m...ay-new-pb.html (vid inside)
This kind of racing would shred that stock LS1 DS.
Old Jun 9, 2009 | 02:56 PM
AChotrod's Avatar
BTW Im running a Strange CM DS now also
Old Jun 9, 2009 | 08:42 PM
gregrob's Avatar
That's the shiat right there, but $$$$
Old Jun 9, 2009 | 09:56 PM
the_merv's Avatar
Veteran: Air Force
I got mine to puck up both the front tires without a problem on the LS1 DS..this was back when it was an Auto. I blew the 10-bolt to **** with that DS too..lol
I had a 3600 Stall and 3.73 Gears, consistant 1.56-1.58 60ft times. I was using MT ET Street DR's, 275/50R15.
I guess some of us have luck and some dont.
Now with the T56 in the Car I see it shredding easily..
Old Jun 9, 2009 | 10:45 PM
Z-RATED94's Avatar
Don't foget videos, muliple pics, and a dozen certified witnesses or a few certain people will doubt your claims.
Old Jun 10, 2009 | 01:07 AM
gregrob's Avatar
It's not called luck it's called "just-a-matter-of-time".
Being an auto is the only reason you got as far as you did on it IMO.
Old Jun 10, 2009 | 01:15 AM
  #32
tspence45's Avatar
Through an M6 with Nitto DR's, and some suspension work, I'm yet to destroy mine. And I've gone to the track 4 times in the past month and a half. I'll probably take another trip in about 2 weeks once the 3.90's are in, and I put my new TB on. Hopefully the 1.7RR's will be put in by then too.
Old Jun 10, 2009 | 02:39 AM
  #33
I8ASaleen's Avatar
Those DS's look like aluminum foil! Holy crap, I'm just gonna get mine rebalanced!
Old Jun 10, 2009 | 06:02 AM
  #34
letsrun97z's Avatar
I woudnt waste your money on the rebalance... I wasted 140 on mine new ujoints aswell and was in the same position they said it was good to go and had the same vibration. ls1 ds fixed the problem
Old Jun 10, 2009 | 06:32 AM
  #35
leadfoot4's Avatar
Originally Posted by BTC
My car used to have the shakes at higher speeds, so at some point I'm going to get a new driveshaft. I was considering the Lingenfelter shaft, but I looked the other day and they were 500 bucks. They've either gone up quite a bit, or I just don't remember how much they cost.
I picked up a Lingenfelter shaft several years ago, when they were having a sale...$300, IIRC. However, I also took my stock steel shaft ('96 Z-28, A4) to the local d'shaft shop prior to that, and had the u-joints replaced, and rebalanced. Bottom line, no vibration in either shaft, so if for no other reason than having a "trick" d'shaft to look at when the car is on the "grease rack", I could have saved myself $300.....
On the other hand, I don't race the car, except for an occasional 50-110 MPH "blast" on the expressway, when there's no other traffic around, and sadly, that isn't too often.
Old Jun 10, 2009 | 06:34 AM
  #36
moehorsepower's Avatar
For a lightly modified car the LS1 DS is ok. Cuts the vibratiion out. but for brute strength...No, I run a Dennys chrome moly shaft but then again I run 138 mph in the 1/4 with 612lbs of torque
Old Jun 10, 2009 | 07:14 AM
  #37
Internet Mechanic
Yea, my car in the pic is an M6 car. Its busted up my tru-trac.
Old Jun 10, 2009 | 08:42 AM
  #38
the_merv's Avatar
Veteran: Air Force
Ya I know right..lol
I know..that's why I said with the T56 I'll kill it.
Old Jun 10, 2009 | 09:45 AM
  #39
Formula383's Avatar
I see your torque and raise you 132 ft-lbs...
Old Jun 10, 2009 | 10:20 AM
  #40
BTC's Avatar
BTC
I sent an email to LPE yesterday inquiring as to whether they ever runs sales on those driveshafts. They responded within 30 minutes and said they don't produce enough of them anymore to offer special pricing. My car is on jack stands, and will probably never see the track, or be heavily modified, but I would like to replace the driveshaft with something lighter as opposed to balancing the stocker.
